Replaced Hubs & IWE actuators, looking for IWE Vacuum Diagrams
Old 11-15-2015, 11:17 PM
monkey_nuts's Avatar
monkey_nuts
monkey_nuts is offline
Hi guys, I just replaced my actuators & hubs (and rotors) and everything is working as expected.
I've been browsing the IWE threads & see reference to check valves and vacuum reservoirs, I've also seen reference to a vacuum system.
Can someone point me to the next tests I should perform, along with a vacuum diagram?
Before I started today the gears were completely worn out. I want to make sure this repair is done right & that it lasts.
I replaced the actuators & solenoid last year and it worked for about 3 months. This time I replaced the hubs too.
...2006 F150 SCREW, XLT...
Old 11-16-2015, 09:58 AM
monkey_nuts
Should I go ahead & replace the check valves? I haven't found them online at either Autozone or Amazon.
Old 11-16-2015, 01:52 PM
monkey_nuts
I just put the vacuum gauge on it, vacuum went to 15 immediately, crept to 17 psi after about 10 seconds; when I turned the engine off the vacuum held for 9 seconds and then abruptly dropped to zero. Both sides behaved identically.
Old 11-16-2015, 09:58 PM
EBC-150's Avatar
EBC-150
EBC-150 is offline
You need to remove the check valves to test them. Try blowing thru them (by mouth) each way. If you can, replace them. These are the valves I used:
Amazon.com: Motorcraft DY260 Distributor Check Valve: Automotive Amazon.com: Motorcraft DY260 Distributor Check Valve: Automotive
(2 of these)
Amazon.com: ACDelco 14047619 GM Original Equipment Cruise Control Vacuum Harness Check Valve: Automotive Amazon.com: ACDelco 14047619 GM Original Equipment Cruise Control Vacuum Harness Check Valve: Automotive
(larger valve by the brake booster. I know's it's an AC Delco, but it has worked flawlessly)
Old 11-17-2015, 08:32 PM
bbender85's Avatar
bbender85
bbender85 is offline
TheGreat460
05-11-2020 03:25 PM
Linda L Lampton
1999 to 2016 Super Duty
10-30-2018 07:06 PM
firegod42
08-10-2017 12:08 PM
mackstruck
02-26-2010 11:22 AM
sleek122
07-30-2008 02:05 PM
Quick Reply: Replaced Hubs & IWE actuators, looking for IWE Vacuum Diagrams
