2012 4x4 not engaging.
I've got a 2012 F250 with the 6.2l with about 45,000 miles.
The other day I was pulling someone out that was stuck, I was in 4wd and I noticed my back tires started spinning and the fronts were not.
Afterwards I got on pavement and tried both 4x4 high and 4x4 low, they both light up on the dash like normal, but it is not engaged.
I assume this will be covered under my power train warranty, but was wondering if anyone else has had a similar problem? Or any ideas on what to check out first?
Rule of thuimb is to perform a 4x4 hi and low test once every month. While performing this test, it should be done while turning the hubs to lock and unlock. Most important. Perform this test on a loose or unpaved surface. The vaccumm lines do fail from time to time. Which reminds me, I need to make sure everything is ready to go for this winter.
I have auto hubs, but I can also lock them manually. In fact when I had to pull someone out when I noticed that the 4wd was not engaging I put it in 4 low and got and locked the hubs. I didn't notice if that made the front tires spin but I yanked that truck right out.
I will test them today by manually locking the hubs.
This one spurred me on to check mine out before the snow starts flying around here. thanks for reminding me
Checked 4hi and 4 low both auto lock and manually locking and everything seems to be working fine. But I did notice my right side hub was extremely hard to turn to the lock position. Is this something I should be worried about?maybe replacing them be in my future plans?
So somehow my hubs are not locking when I turn the **** to 4x4 high or 4x4 low. I assume the computer doesn't know they are not locking since the 4x4 lights up on the dash like normal.
I crawled around under the truck looking for something obvious like a connector or a hose popped off and didn't see anything.
Crystal
