Brake Drum Removal - D60 Rear
Old 11-15-2015, 08:03 PM
Blue and White's Avatar
Blue and White
Blue and White is offline
Its time for new drums on my '78 F250. Hubs and drums are off and I cannot see a good way to remove the drums from the hubs. The FSM says remove any fasteners and separate them. There are no fasteners to remove.
Is this a press or pound deal? What are the chances I can get the 35 YO drums off without damaging the hub? Tricks and suggestions welcome.
Old 11-15-2015, 08:21 PM
9thPony's Avatar
9thPony
9thPony is offline
Did you remove the wheel studs? Usually once you knock those out it comes apart pretty easy.
Old 11-15-2015, 08:32 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Gotta knock the drum off the hub. I suggest using a press.
Old 11-15-2015, 08:34 PM
Blue and White
OK studs first. Is it OK to put a junk nut on them and pound them out or is press better? Also, any possibility to re-use or best just plan on new studs?
Old 11-15-2015, 11:24 PM
OldMetal's Avatar
OldMetal
OldMetal is offline
A press is best but I have simply put the lug nuts on the lugs and knocked them out with a hammer, usually they are reusable just be sure the nut is even with the lug.
Not the best method but it works when it's all you have
Old 11-16-2015, 12:35 PM
Notmeofficer's Avatar
Notmeofficer
Notmeofficer is offline
Agree... doesnt hurt studs
Saves thumbs....
The lug nut method deforms the nut and thread ..even if you cannot see it...... no mistakes when it comes to safety.. lugs and lug nuts are really important ..don't you think?
Old 11-16-2015, 09:07 PM
Blue and White
I've got a press and will use it to get the studs out tomorrow. Replacement drums/shoes/ect. on the way from NAPA and in tomorrow also. I'll post how it turns out.
Old 11-17-2015, 05:52 PM
Blue and White
I pressed out the studs and it came apart easily. The studs and hub are fine. Thanks guys.
Otterby
01-14-2019 09:17 PM
Tim Moffett
09-04-2003 02:10 PM
csft
07-06-2003 02:13 PM
cashs66
06-27-2003 10:04 AM
FarmallFan
09-12-2002 11:50 AM
Quick Reply: Brake Drum Removal - D60 Rear
