56 F-100 hood dowell pin parts assembly.
What is the correct order when installing the hood dowell pin? Is it dowell pin,spring retainer cup, spring, then push it up through the dowell pin plate hole in the upper front of the hood, then use the two nuts to hold it and lock it in? Or do you do as above, but you leave one nut on the spring side of the dowell pin,then the other nut holds it all together through the dowell pin plate hole ? Not sure mine is right....
hooler1
11-15-2015 06:50 PM
raytasch
09-08-2013 07:17 PM
ssj7kids
10-26-2011 09:04 PM
