93 f150 tie rod end replacement
I'm going to put on the new rod ends for my 93 tomorrow if the weather isn't too crappy, and while under the truck ill see how bad other parts are. Does anyone who has done this know what tools ill need? is it really as simple as i think? remove the tire, measure the distance between the grease nipples on the old ends, have a jack stand under the beam, remove the cotter pin and nut from the rod end, remove the nut from the adjusting clamp, smash the ***** out of the old rod end until it pops out of the knuckle, pull out the rod end from the clamp, and reverse the process with the new ends?also, anyone use mas rod ends before? they were all i could afford at the time, but i do plan on replacing all parts in the front with moog
That will get you close, close enough to drive to the alignment shop anyway.
It would be one thing if you were reinstalling the rod ends, but new tie rod ends may have enough variation to bugger the toe-in. Just slightly off, can ruin tires rapidly and it won't handle right.
Setting the toe is a DIY affair with some string and jackstands on all 4 corners, although I haven't tried it. Supposed to work really well if you take your time.
Figured out I was tightening it not loosening it. Someone might have told me the outer rod ends were reverse threaded and I must be just forgotten lol
I meant if it wasn't cold enough where I can't feel any part of my body within 20 minutes haha. It was 3°C yesterday, and for the last week and a bit it was -15 to -20°C
It's done that way so that you can connect both ends, and spin the rod to adjust out or in without having to remove one end for each adjustment.
kxbronco
12-19-2006 08:21 AM
