V10 swap to 460 are the blocks the same?
Old 11-15-2015, 11:42 AM
Dmd56's Avatar
Dmd56
Dmd56 is offline
Hello, I have a 04 F350 shuttle bus that threw a crank bearing. I want to switch to a 460 out of a motorhome. The question being is the blocks the same? The V10 has all the heavy duty alternator and a/c units. Will the brackets and pulleys mount to the 460 off the v10 without major modifications?
Any insight would be greatly appreciated.
Thx
Old 11-15-2015, 03:22 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,570 Likes on 1,049 Posts
The only thing the blocks have in common is that they both are in the "V" configuration. NOTHING that bolts to the V10 will bolt to the 460. You'll need all new front end parts, transmission, wiring, computer, and probably engine mounts, too. This will require major work and fabrication.
MN_Viking
1999 to 2016 Super Duty
12-22-2023 05:17 PM
ATC Crazy
Engine Swaps
04-02-2006 10:16 AM
Indybroncoman
Modular V10 (6.8l)
08-17-2004 08:41 AM
Skeetkiller
03-06-2003 02:33 PM
Quick Reply: V10 swap to 460 are the blocks the same?
