What happens if/when...
What happens if or when you get air in your brake lines and the air gets into your ABS pump/module? What are the symptoms? Anything other than a soft pedal? My ABS module keeps thinking one of my tires is sliding when i am driving and pulses my pedal and i am at a loss.
thanks
thanks
Received 3,106 Likes
on
on
The ABS fires if it thinks one tire is significantly slower compared to the others. You may or may not have air in the system, but you do have a sensor problem.
At the moment you start to depress the brake pedal, do you feel the pedal "thump" the sole of your foot one time?
A new symptom its having is when the brake pedal is stiff i noticed the speedo will freeze at the speed the truck is going
on
While I agree with Tom, that your module might be failing, before you go any further, try the official bleed procedure instructions from Ford.
Go to the Excursion forum and click on the sticky thread "Excursion Forum Tech Folder" and scroll down to the "Suspension, Steering, Brakes, Wheels, Axles, Hubs, Transmission/Driveline" section.
In the "Brakes, Wheels, etc" subsection, click the link for bleeding your brakes and follow the directions found there to see if it helps.
Stewart
Stewart
You likely have a sensor or bad wire, probably at the output of the transmission. That is could jack up your speedo and ABS.
IS the ABS module also part of the ABS hydraulic module? Can you install the separately? I just had the ABS module replaced but i think they only replaced the hydraulic side because 6 months ago my pedal was "sinking" and then harden up and it was a internal hydraulic leak in the abs module.
on
you can not buy the module separate from ford, but you can remove the module from the pump and replace it.
i did it about 6 months ago on my 02 diesel after a headlight wire broke off the snow plow adapters and fell on the module shorting it out.
i had a spare module and pump i took out of a parts truck a few years ago.
rbrad6937
08-19-2009 05:11 AM
