2015 upfitter & CB radio
I've seen the YouTube videos and the threads on this forum where folks have hooked up the upfitter switches to power lights, air bag compressors, etc. I have found the wires under the dash for the switches and the firewall pass-through wires. But how do you guys get up under the dash to make the connections? I can't contort my body enough to get under there, let alone use two hands and a flashlight to do any work! Also under the hood, behind the fuse box? I can't even get one hand back there let alone two. So how do you do it? What are people who aren't "handy" do to get things hooked up? Do they go to the dealer and pay their labor rate? Upfitter switches were a big selling point for these trucks, but who knew they were a do-it-yourself project to make them work? Right now, I'm kind of thinking about taking it to my local audio installation shop where they have folks with small hands, and experience, to at least give me some longer pigtails. Any advice would be helpful.
I use a CB radio when I am caravanning with my RV friends. I haven't seen anyone's installation of a CB. I use the type that has all of the controls in the handset so the "box" can be installed out of sight. I plan on making a bracket to install the antenna on the left to match the AM/FM antenna on the right. I had that on my last truck and I like it. How have you installed your CB radio?
Here's the tech folder:
https://www.ford-trucks.com/forums/9...ch-folder.html
Then either scroll down or search (Ctrl+F) for upfitter.
Oops, sorry. Didn't see where you found it, but I'll leave it for anyone else.
I like the idea of mounting it on the inside the console. It looks like there is room. I'll just have to figure out how to dismantle it.
Not necessary. Just remove the fuse box cover and they can be reached. Once I got to them I soldered 10" pigtails on them for future ease of access. Did the same for the inside pass thru and up fitter switch wires.
I did the same thing-soldered pigtails on all 4 wires-figured that while I was under there... I also connected all 4 wires from up fitter switches to the pass-thru wires while I was at it.
