Dome light woes dang keys
So I locked my keys in the truck and road side assistance pried the door with the hand pump airbag. After wich the dome light wont turn off. The drivers door wich they pried remains open about 2mm more then the passage light but if I lean on it the light still dosent shut off. This is a 2010 ford ranger. Any suggestions as to what I should try/check first? Thank you.
