can ac be bypassed by just changing belt?
you need to SEE if a KIT is available..
a pulley and bracket to replace the AC unit..... so same belt.
and in most cases . without the kit.. you need to measure very carefully to FIND IF a size is available... and that you do NOT change the rotation of all pulleys.
HERE YOU GO..
.http://shop.advanceautoparts.com/web...lVehicle=false
I have used these kits in the past.. they fix and work.
HERE YOU GO..
Did you know you can change the A/C clutch bearing without discharging the A/C system? The bearing alone is like $20.00 and the entire clutch assembly with the clutch, hub, pulley & bearing is $50.75 from rockauto.com so you can see what I'm talking about. Go to rockauto.com click on make, year, make, model & engine click on Heating & A/C then click on A/C compressor clutch you will need to get the special tool to remove the clutch assembly but I'm sure both Auto Zone & O'ream Me's rents the tool for free. Check it out. It might less trouble to fix it than you think. Hope this info helps.
