Extremely high idle problem
Old 11-14-2015, 01:00 PM
Lowpala's Avatar
Lowpala
Lowpala is offline
Recently my truck has been idling really high, don't have a tach but I would guess around 2k RPM. When I'm stopped if I blip the throttle real quick it will return to normal idle, but if I gently touch the throttle it will return to the same high idle. Any ideas what is going on?
1980 f150, carter carb ds2 ignition
Old 11-14-2015, 05:42 PM
maytag906's Avatar
maytag906
maytag906 is offline
Choke linkage sticking?
Old 11-14-2015, 09:07 PM
Lowpala's Avatar
Lowpala
Lowpala is offline
I guess it sort of seems like something sticking, I'll check it out and oil all the linkage see what happens
Old 11-15-2015, 06:43 AM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
You choke might need a minor adjustment or your heat tube is broke off to the choke if you have that type.
Old 11-15-2015, 07:52 AM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
I would avoid oil as it tends to attract grit and bind things up worse over time.
Flush it out w/ carb cleaner while working the choke by hand.
Use a dry film lube like graphite or TDL from PB Blaster.
MikeandMoon
12-30-2014 01:27 AM
jameson8808
02-04-2011 11:50 PM
gotjeepzj
07-19-2010 01:58 PM
yellow78ford
03-23-2007 12:29 AM
youngguy
04-02-2004 09:10 PM
Quick Reply: Extremely high idle problem
