Coolant ?
Old 11-14-2015, 10:15 AM
CapeMay609's Avatar
CapeMay609
CapeMay609 is offline
Exclamation Coolant ?
Hey guys, I have a 2006 f150 lariat 5.4 triton I just purchased a few months back with 80,000 miles on it.
I recently have been hearing a gurgling or even a water sound from under my dash board on cold mornings. Note I don't even use my heat or air conditioner and I drive about two miles to work, park my car and turn it off and for a minute or so I hear gurgling or a slushing noise. Note some days I don't hear it when it's 60 degrees outa X warm for the day.
Now a week ago I took it to the dealer and they said yes your heater plugs were clogged, they fixed that and I can now still hear the noise....
So I have been searching around and allot of website have been saying that it's my coolant level. Now I just drove to work and here is a pic of my coolant level. I'm just new to all of this guys and if you cold give me some advise please do so, thank you
(Also what kind of coolant should I buy?)
(I live near a Walmart, Napa, autozone and advanced auto parts)
Old 11-14-2015, 03:14 PM
Black Helmet's Avatar
Black Helmet
Black Helmet is offline
In my '05 5.4 I use Motorcraft "gold" coolant (ordered from Amazon), but Zerex should work with it as well.
Old 11-14-2015, 04:56 PM
CapeMay609's Avatar
CapeMay609
Thank you guessing I will have to look around or order online
Old 11-14-2015, 09:55 PM
Black Helmet
It was the easiest option for me, as I was not in any big rush (just wanted to flush and re-fill). Also, sorry I completely neglected to comment on your other question! I'm not sure what to tell you about the noise you are hearing in your dash, possibly something related to your heater core? Also, your level does not look crazy low to me. But topping it off wont hurt anything, and if it fixes your problem even better! Please update this thread once you know how it's going to play out. Good luck!
Old 11-15-2015, 07:22 AM
CapeMay609's Avatar
CapeMay609
Just to keep anyone up to date who is taking a look at this thread I just drove to work which is a 3 miles drive and halfway there I turned on my heat and it was pretty high, I got to work parked my truck and in idle It was making the gargle noise louder and faster, so after saying a few choice words I turned off my truck and then it got silent and just made the regular noise like I stated yesterday.
God someone help me lol
Old 11-15-2015, 01:09 PM
Black Helmet
When you say the heat was high, do you mean the temp gauge or just the setting on your heater? It kinda sounds like you have air trapped in your cooling system. Try "burping" your cooling system, as you would do when filling t and see if it helps.
Old 11-15-2015, 01:44 PM
CapeMay609's Avatar
CapeMay609
Burping is what I will do. But I want to buy some coolant first before I burp it. Because from what I hear is you have to jack it up and run it with the cap off but you lose a tiny bit of coolant so I want to have some extra before I try that
Old 11-15-2015, 08:32 PM
rander101's Avatar
rander101
rander101 is offline
Zerex G05 coolant is the same as the Motorcraft Gold and is correct for your engine. Most auto supply stores have it --especially NAPA. The old style green stuff will do evil things to your cooling system. A 50% - 50% mixture of G05 and water is best unless you live where the temps get much below -10 F.
Old 11-25-2015, 06:17 PM
Leroy Axe's Avatar
Leroy Axe
Leroy Axe is offline
The inlet hose has a restrictor in it to stop said noise
The hose may have been replaced at some point and the restrictor possibly left out so check that out first
Old 11-26-2015, 12:09 AM
lballard1129's Avatar
lballard1129
lballard1129 is offline
From your picture and the noises it sounds like the heater core has air in it, low coolant. You mentioned burping, to do that you need to fill it to the max level mark and run vehicle, (with caps on) to running temp until thermostat opens. Let coolant fill passages in engine and in core. After that check your levels and top off as needed. Check fluid level after engine cools, top off if needed.
Old 11-26-2015, 12:25 PM
lballard1129
And it also is strange that you just had the dealership clear out your core and the coolant is already that low, be looking for water leaks.
Oldanvilyoungsmith
84
04-10-2018 05:19 PM
Picton
6.4L Power Stroke Diesel
07-21-2017 11:10 PM
Mark Searcy
34
12-28-2013 07:35 AM
lbrowne
1997-2006 Expedition & Navigator
22
11-03-2011 07:18 PM
hatari
12-17-2008 06:28 AM
Quick Reply: Coolant ?
