1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Comparing 7.3 to 6.4 Fuel Tanks
Old 11-14-2015, 01:52 AM
KTZ's Avatar
KTZ
KTZ is offline
Quick question: All other things being equal (Cab size, bed length, ect...), are fuel tanks and sending units from 7.3 trucks swap-able between 6.4 trucks?
I need to replace my tank in my 7.3 and wanted to expand my pool of possible replacements.
THanks in advance.
Old 11-14-2015, 04:46 AM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
fuel tanks are also dependent on the model and wheel base....you might want to give a bit of info about your truck...
Old 11-14-2015, 05:56 AM
wrvond's Avatar
wrvond
wrvond is offline
My 6.4 fuel door is the same as the 7.3. It has a plug where something for the diesel would normally be. My dealer told me what it was but I've long since forgotten.
So in this case, yes, they would seem to be interchangeable.
Old 11-14-2015, 12:42 PM
KTZ's Avatar
KTZ
KTZ is offline
My truck is a 2001 F350 Crew Cab Short Bed SRW 4x4. Wheel base is 156.2 in with a 29.00 gallon tank (Ford specs). Wondering if a tank from the exact same truck with 6.4l engine would fit, and if the sending unit is the same.
Old 11-17-2015, 04:34 PM
KTZ's Avatar
KTZ
KTZ is offline
Bump. Wondering if anyone knows if they are interchangeable.
Old 11-22-2015, 10:53 PM
KTZ's Avatar
KTZ
KTZ is offline
Bump. One last try.
Old 11-23-2015, 07:52 AM
NotURMailman's Avatar
NotURMailman
NotURMailman is offline
Look up the tank for both trucks on a parts site and see if they are the same part numbers.
Old 11-23-2015, 06:06 PM
podzie's Avatar
podzie
podzie is offline
We replaced ours with a Spectra. Dirt cheap and great fit!
Old 11-23-2015, 11:38 PM
KTZ's Avatar
KTZ
KTZ is offline
What was the spectra part number? You installed it in a 2001 F350 SB CC SRW with the 156" WB?
Old 11-24-2015, 10:58 AM
podzie's Avatar
podzie
podzie is offline
No sir, ours is a 97 CCLB. Wouldn't be the same tank. Sorry, I'm not sure if Spectra makes a tank for your model.
Coolbean1000
18
03-29-2010 09:28 AM
crew68
02-24-2005 11:27 PM
Reptar360
11-01-2004 07:21 PM
xman7896
09-18-2003 12:37 PM
Quick Reply: Comparing 7.3 to 6.4 Fuel Tanks
