School Bus and 7.3 - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Log In
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
School Bus and 7.3
Old 11-13-2015, 07:52 PM
Walleye Hunter Walleye Hunter is online now
Walleye Hunter has a good reputation on FTE.Walleye Hunter has a good reputation on FTE.
School Bus and 7.3
I am eyeing up a couple of school buses and need to figure out what I can about the engines.
First is a 2001 full size bus with rear engine. Advertised as a 466-G 7.3. How does this engine compare with my e-99 engine and would it make a good parts engine?
Second is advertised as a 2004 E-450 short bus 7.3. Were they still using the 7.3 in these in 2004? I expect that if they were that the engine would be a sufficient parts engine for me.
Thanks,
Mark
__________________
E99 F-250 XLT Extended Cab 4X4 AT 170,000
'91 S-15 Jimmy
'79 Cessna Skyhawk
Old 11-13-2015, 09:23 PM
Pikachu's Avatar
Pikachu Pikachu is online now
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
You may have ended up with two buses that don't have 7.3s. The first one might be a DT466, the 2004 is, in all likelihood, a 6.0.
__________________
Boeing 747-400, Early '99 F350 4x4 std. cab, 225k mi.
1995/Late 1999 Frankenmotor engine installed . . .
2326 Air Filter, NAPA 4912 fuel pre-filter (Stanadyne FM100), 2 cent mod . . .
Old 11-13-2015, 10:06 PM
Quote:
That's a little of what I was thinking. The DT is a straight 6 isn't it? OK, the VIN decoder shows the supposed 2004 as a 2003.
__________________
'91 S-15 Jimmy
'79 Cessna Skyhawk
Old 11-14-2015, 06:37 AM
Pikachu's Avatar
Quote:
Yes, the DT466 is an I6, and it's a good one too! The numbers you posted from the (auction?) listing don't really make it clear which engine it is. The DT466 is 7.6 liters. The 2003 could be a 7.3 or a 6.0. If the 8th digit of the VIN is an F, it came with a 7.3, if it's a P, it came with a 6 liter.
__________________
Old 11-14-2015, 11:02 AM
It's an 'F' there, thanks for that information. Maybe I'll get lucky and having it listed wrong will net me a good deal.
__________________
'91 S-15 Jimmy
'79 Cessna Skyhawk
Old 11-14-2015, 03:44 PM
Nicmike's Avatar
Nicmike Nicmike is offline
Proud Sheepdog
Nicmike has a brilliant futureNicmike has a brilliant futureNicmike has a brilliant futureNicmike has a brilliant futureNicmike has a brilliant futureNicmike has a brilliant futureNicmike has a brilliant futureNicmike has a brilliant futureNicmike has a brilliant futureNicmike has a brilliant futureNicmike has a brilliant future
Here ya go!
https://sanantonio.craigslist.org/ctd/5303039855.html
__________________
Mike
2001 Excursion 4x4 7.3L, GH Hydra, 160/30, 38R, 910 Valve Springs, Melling M208, T444E water pump, Bellowed ups, 4R100HD, Precision billet 3 disc TC, JohnWood VB, 6.0 cooler, 4" turbo back, AIS, HPx, FRx, Hutched, V coded, AIH/EBPV/foil delete, F350 rear sway, drilled/slotted, Fumoto, Glowshift MT/DV - EGT/fuel/boost/trans. temp, 261k All modifications AND repairs made by ME!
Old 11-15-2015, 12:34 AM
Quote:
Originally Posted by Nicmike View Post
Those are about $3000 more than I'm willing to shell out. Have seen some short buses go in the $500-$800 range when the auction closes at odd hours.
__________________
'91 S-15 Jimmy
'79 Cessna Skyhawk
Similar Threads
Short Bus E-450 7.3 Walleye Hunter 1999 - 2003 7.3L Power Stroke Diesel 5 10-28-2015 11:45 AM
Timing belt or chain or none? holyspirit 1994.5 - 1997 7.3L Power Stroke Diesel 7 06-03-2015 04:36 PM
Ilya. this has your name on it! jmadsen 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 02-04-2015 07:56 PM
1990 Ford Econoline E350 Shuttle Bus Engine Rebuild? amandawolf89 1968-2013 Full Size Vans 6 01-15-2015 12:21 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
