Body swap
Body swap
I have a late year 1977 ford f250 4x4 single cab 8ft bed. It has a good bit of rust throughout the entire truck so rather than patching every spot, I was thinking of doing a body swap with truck bed also.
* Now I would really like to have the extended cab version with the 6ft bed but I don't know if my frame is compatible.
* Next question is, will a single cab 8ft bed f150 body and bed bolt right up onto my f250 frame? If so what years are compatible? The same question for the extended cab version?
can someone point me in the right direction.
thanks in advance
thanks in advance
Both swaps have been done before.
I assume by "late year" you have a non-Highboy truck. If so, you have the regular frame spacing and an f150 reg. cab, long bed body will bolt up.
A Supercab/shortbed body swap is more involved, since Ford never offered that configuration in 4x4, the 2wd variants had a 139" wheelbase. So you'll either be cutting down the bed or stretching wheelbase.
just late 77,78 and 79 will bolt up directly, to your truck ,other years will have to be custom fit.
No, cab mounts are different as well.
