Your safest bet would be to find the parts diagrams for 2013 and 2016 and compare the part numbers. For parts that are the same but with different numbers, Ford usually notes that a part number has been super-ceded. Also, check the part numbers for aftermarket parts - they should be the same.
Are you after a lift kit? They are gas or diesel spring rates for the most part unless you find progressive rate or coil overs. Front coils will be different rates for snow plow packages. The rear I believe may be stiffer with depending if a camper package. Depending on gvwr there might be helper springs. The suspension design is the same though. I installed 4.30s, most dealer lots will only have 3.73s
Ok, lift kits won't matter. 11 thru 16 will fit. Best to call the company and ask for your application. That will get you the correct kit and any additional parts.
