Anyone thought about a GASSER truck build ?
I've lowered my truck by cutting 2 coils and had the beams cold bent for a 4 inch drop but still hits the cross member once in awhile. I cut another coil and was bottoming out but slammed the front 5 inches . So I raised it with washers back the coil I cut and been running for 3 years . So when I jacked up my truck and lived the look I thought about running full progressive springs to raise it like a gasser on beams . I know the camber will be positive but only drive it once in awhile. This couldn't be done on a stock front as high as mine because of bent beams for lowering but I always could change back . I took a pic in my photos jacked up . The back is lowered about 5 already . Anyone thought of this ? You could just lower the back and keep front stock for the aggressive look of a gasser without putting a straight axle . Just a thought . I'm back btw , been gone off here for 4 years ...
78streetbeast
08-12-2016 04:00 PM
nick01psd
07-31-2013 06:22 PM
Chocko
23
06-27-2013 05:59 AM
overlandexpress
22
12-03-2009 10:50 AM
