Replacement radiators for 96' 7.3 with 5-speed
Old 11-18-2015, 10:52 AM
nossliw's Avatar
nossliw
nossliw is offline
Originally Posted by lee00
Actually there is an acid solution that HVAC guys use to clean heat pumps and the like that foam when sprayed on the fins and expands pushing the dirt out... real nasty stuff...but it works and washes away with a garden hose..
I have seen that before...just don't use muriatic or too much of it on aluminum...it munches aluminum like nobodies business...
Old 11-18-2015, 11:01 AM
lee00's Avatar
lee00
lee00 is offline
The stuff my buddy uses is designed specifically for aluminum condensors...
Old 11-18-2015, 12:51 PM
madMatador78's Avatar
madMatador78
madMatador78 is offline
I just ordered one for GW. Cant beat that price. Thanks Nick!
Edit: Tried to rep you Nick, but was denied....
Old 11-18-2015, 01:43 PM
tlapham's Avatar
tlapham
tlapham is offline
Interesting to note here is that there is no dirt clogged in the A/C condenser coil. it was trapped in between the radiator and condenser... none of the dirt was visible from the outside.
Washing with air cooler cleaner would be difficult since it would be impossible to determine if you were just washing the dirt into the a/c condenser or vice versa. the filter screen in front of the condenser would be the an excellent idea.
Now that i have a good clean radiator, i will probably get to work on that. i regularly drive dirt roads, sanded highways in the winter, and there are always cattle and hay trucks driving in front of me with loose crap flying into the truck.
Old 11-18-2015, 02:44 PM
nossliw's Avatar
nossliw
nossliw is offline
Haha no need. Glad you got it cheap. I had to put two new radiator in a couple SDs this week. I feel their pain on the 800$ plus figure.
230 is an incredible price. I might pick up a second one for the buggy build!
Old 11-18-2015, 07:09 PM
madMatador78
Its only like 6 bucks more than an oe one from Napa. That's my cost! It's a no brainer!!
Rufusjivefunk
18
06-20-2019 04:47 PM
Becky_is_a_66
29
07-04-2016 07:35 AM
crazy96863
28
11-29-2014 10:00 PM
bad12jr
11-06-2009 10:15 PM
unrulee
06-07-2006 01:04 AM
Quick Reply: Replacement radiators for 96' 7.3 with 5-speed
