Truck stopped running today-fuel pump
Started my 76 f150 with the 390 today. It was idling rough then died. It took a little to start back up and wouldnt idle without giving it gas. I started driving and if i kept it in a higher rpm it would drive okay but a little rough sputtering a little. If i shifted to 3rd it would sputter jerk and not really go. my first instinct was fuel pump so I replaced it. After trying and trying to start it still wouldnt start. I checked for spark and it is getting a spark. it is for sure getting gas. Where do i go next. is it carburetor problems. Im lost.
How often does the truck get run? Every week, every six months? Have to ask these questions to eliminate the obvious.
When you say it has spark does it have good spark - fat and blue and snaps in the air? Or weak and orange?
Is this a high mileage engine, what is the history - recent rebuild, etc.
First thing, not trying to pick on you, but help others who will read this - with an engine that won't start, always put the battery on a charger. Marathon cranking just wipes them out. Take it easy on the starter too, they will get smoked after a few start attempts. Give it several minutes rest between cranks. A well tuned motor lights off instantly.
That truck is a little too new for me, but basically you need to find out why the spark is weak, assuming this is the issue.
Probably some fancy module or other gee-gaw. BUT, one thing that I've learned is that anything electrical needs good grounds and connections, and unless you've already made some real effort in those areas everything will be corroded badly on a 1976 rig. An invisible layer of crud is enough to make connections fail.
start here: http://www.aa1car.com/ignition.htm
Maybe the coil
Where were you checking the spark? Where the coil wire went in to the distributor or at the plugs?
If I remember correctly, those engines had a separate coil, (not mounted on distributor) and would go out fairly regularly..I would be inclined to think with a weak spark, the coil would be the culprit.
Points? In '76? May be, but I thought those were done by '74 or '75.
"After cranking and cranking it still won't start." Be careful, you'll roast the starter, and this may cause other problems.
Here is a direct link to a comprehensive "won't start" troubleshooting page. What have you determined so far? You have a voltmeter, right? Nod your head "Yes."
http://www.aa1car.com/library/us1296.htm
Today i solved my problem. after figuring out we had a very weak spark, I was recommended an HEI Distributer and there was one at a local shop. It gets rid of all my point and condenser nonsense so I thought I might as well go for it. It was 150$ and I am very happy I did it. After installing it with some new HEI plug wires it fired right up. After timing it runs like a dream. It starts up very quickly and there is a significant performance upgrade. The engine runs so much smoother now. I Highly recommend it to anyone interested. I still need to clean up the wires and get a riser for the air filter or a smaller air filter. If anyone knows of an easy solution please let me know. Any questions about the install feel free to ask.
