power steering reservoir replacement
#46
#47
#48
Hey I got an idea. Can you get to the mounting ears on that pump from the back if you remove the accessory bracket? If so they are only cast aluminum and you could easily cut them with a standard cutoff wheel or even a Dremel cutoff wheel if it's hard to reach.
Last resort... air chisel. Because that may or may not break the bracket.
#49
No, mounting ears are on the pump. If you look at the body of the pump it will have I think three ears cast into it. These are what the bolts thread into after they pass thru the accessory bracket from the front.
If you can break or cut those ears off the pump body it will come right out. Because if I remember right the mounting area for it is not completely enclosed but rather it resembles a C shape.
Also... you could just cut the (plastic) pulley off the pump and remove the mounting bolts normally.
#51
#52
#53
But yep it came right off. It was so enjoyable cutting that pulley ,then breaking it into 3 with my chisel and mallet, took all of 10 minutes to get that pump out.
I'll make sure to get the threaded adapter too I guess I could still use the puller tool to reinstall the pulley.
#54
No worries... you're still learning (I am too when it comes to some things) and it ain't like you hijacked someone else's thread... this one's yours. I'll continue to reply as long as you're doing what's suggested or otherwise making progress. The threads I quit helping in are the ones where despite multiple members telling someone to do things a certain way, they go off and do other things instead such as replacing parts instead of troubleshooting. After all, if someone won't take the advice that is given then what good is them asking for help in the first place?
And your little project will forever be here for others to find and learn from, maybe saving them the trouble of going thru what you did, so it's all good in the end.
#55
#56
Okay! I finally put the pulley and pump on. It came with everything I needed even its own installer bolt. I replaced the white Teflon seal and for extra measure added a layer of teflon tape. Took me 1 and half to get the pulley on.
I would like for someone to tell me if the pulley looks flush enough with the shaft of the pump. Belt lined up good visual inspection appeared to show the pulley was in the necessary range.
Now to put this darn thing back together and bleed the steering.
#57
Looks okay to me. Can't look at mine because I have an aftermarket dual belt pulley on my pump but I'd say if the belt lines up and don't fly off at high RPM then it's gonna be just fine.
Oh and the hydraulic system is self-bleeding. You don't HAVE to bleed it but it will whine for a bit til the air gets out. If you really want to though, all you do is jack the front end up and turn the wheels back and forth til it quits whining. You may not get all the whine out of it or maybe you will, these pumps are just not quiet to begin with.
Hey is that a METAL pulley you have now? That's nice... I was looking for a metal one when I did my air compressor. Wanted to take a steel one and weld a second pulley on it but all the ones I saw were stupid plastic so I had to buy an aftermarket one for a not-so-nice price.
#58
#59
Yeah some whine is normal from the C2 pump. Don't think I've ever heard one didn't. Mine whines constantly since I put in the hydraulic brake booster. Someday I'm going to swap in a quieter and better C3 pump from a 4.6/5.4 motor but I'll have to make a custom bracket to mount it first. All hydraulic pumps whine but this is just a bit excessive although nowhere NEAR as loud as I've heard one of these C2 pumps sing.
Good deal on that steel pulley. I'll have to remember that.
#60
Yeah it is metal actually(I was surprised myself) ... and the holes in the pulley made installation quite abit easier.
"And yeah I heard the whining which made me nervous , but it went away as soon as I put the truck in gear so all is well and I'm glad you told me that about the steering I'm not even gonna bother bleeding it now.
Opinions differ on bleeding out the system but depending on how much fluid is in it, you can run the pump dry in a matter of seconds potentially damaging it. I jack up front wheels, turn the wheel back and forth several times, top off the reservoir. Do that a few times and then start the engine and repeat until no more bubbles are present. (Shutting off the engine to check the level and top off)
