91 300 EFI to Carb
91 300 EFI to Carb
Have a 91 EFI 300 I'm swapping to a carb using parts from a 66 240. Looked through these forums but had a few questions.
Seems the 240/300 is internally balanced, any issue then with using the crank pulley and flywheel from the 66 240? Manual truck if it matters.
Looks like most heads are interchangeable from these engines but the EFI heads are different with the combustion chambers. Is it worth trying to keep the EFI head, plug the EGR holes, and recurve the distro or just swap the 240 head over? I'm swapping the distributor from the 240 also.
Thanks guys.
Thanks guys.
Thanks guys.
Thanks guys.
This was recently discussed in another forum. Perhaps this link will help: FORDSIX PERFORMANCE ? View topic - Crankshaft Pulley
Thanks guys.
Thanks guys.
If you plan to run the 240 distributor you are better off swapping the 240 head on to it.
You will also need to swap to the 240 waterpump & pulley. The 91 will have a reverse rotation waterpump and a serpentine smooth pulley. Plus the EFI water pump is designed to use a fan clutch assembly.
If you just run the 240 distributor with the efi head as is, your engine could have some pinging under load. Pre-ignition may also be a problem.
Run what you want, it's your truck!
Put it together this weekend, went fine mostly but there were a few little things that came up, if anyone else does this. I had to mix and match on some things between the EFI and carb engine, bolts are one thing I remember. The motor mounts didn't fit exactly on the passenger side, bolt hole was about 1/2" too high. Used intake gaskets from the 66 and oil pan gaskets from the 91. Swapped oil pan just so there are no clearance issues, the dipstick will need to be modified now. Wanted to use the EFI exhaust but one bolt ear would not fit in with the 66 intake, would have required about 1/2 of it torches or ground off; used the OE log exhaust for now.
Still looking for a carb then I can fire it up. Electric fuel pump is on the way, may swap that 240 head if the pinging is an issue.
Thanks again for the help.
5.0Torx
33
02-14-2008 11:49 PM
