95 super duty auto transmission problems
Hi all,
Recently picked up a 95 flat-deck super duty with a 460 gas, not bad looking rig and traded it for a pallet of siding. Win. The transmission shifts a little rough and the overdrive light on the shifter flashes at me. Oil level is good and is clear and doesn't smell burnt. So, two questions, what transmission do I have (can't find a tag)? And any obvious reasons for the troubles I'm having? Thanks in advance, Alistair
If the speedometer doesn't work, most likely the number won't change. What that _usually_ means is that the PSOM ("brains" behind the speedo/odo) is okay, but the VSS - vehicle speed sensor in the rear diff, is inop. That also serves as the speed signal to the transmission. So no speed signal will cause a code (and thus the OD-OFF flashing), and no speedometer, and hinky shifting. Might not be the _only_ problem, but that's where to start. Hmm, the F-SD may have a different axle, but I *THINK* it's like the pickups, and the VSS is in the rear diff, forward side toward the left. Check that connector, check the wiring as much as you can of it.
If you're lucky, and get the speed signal back, it _might_ solve the tranny problems.
