Help i need a new exhaust system have some questions!
i JUST GOT THE CLUTCH together and new engine set in place, i need a new exhaust y pipe and muffler system with all the pipes in between. the truck came with no pipes. how do i know if i have a 168" Wheelbase or a shorter wheelbase. its a long bed idi diesel. 1990 f250
This would be a great time to find a turbo kit; it requires different exhaust as it is.
If not, just find a crossover pipe(the only part that is hard to fab), and then talk to your local muffler shop. They can probably bend some pipe and weld in a muffler cheaper than you can buy an already-built piece. Or you can do it yourself with clamp-style fittings(I'm assuming you can't weld exhaust pipe yourself).
X2 on turbo, but the wife won't let me get one just yet, so also X2 on fabbing or having a shop get you a better than stock setup.
A few of us N/A guys have put in a real Y-pipe instead of that joke that came with the pickup, and it certainly helps!
Mine was a walker 2 1/2"x2 into 4" outlet. But no shop that I found around here could bend 4". In fact they could only get to 3" max. So I had to do it all myself anyway...
But you could get the walker Y and have them put it into the system and build around it. Much better than stock
BIDIL
02-05-2017 12:16 PM
Agemenon
10-11-2006 09:41 PM
