Parting 7 obs trucks 87-96
#108
Do any of the 92-96 gas trucks have the factory tow wiring?
If so can you get the wiring including the auxiliary relay box and the harness all the way back to the hitch?
I can get you more details if that's not clear
Also a tach cluster for a gasser 92-93?
#111
This will only be on a truck with the factory two package, my truck has a hacked up harness from the PO splicing in his own trailer wiring.
The Auxiliary Relay Box attached to the Underhood Fuse Box pictured in Post 11&12 here https://www.ford-trucks.com/forums/1...er-wiring.html
And the Harness going from that relay box to the back of the truck, heres a picture of the engine bay side of the harness including the relay box
The harness runs down the Driver's side frame rail under the bed, and connects to the fuel pumps, taillights and ends with the trailer plug.
The middle diagram in this image is the schematic for this harness
Can come off a 150 250 or 350 1992-1996/7. Preferably gas but I believe diesel would also work.
Thanks!
Thanks!
#113
I believe it was a pretty common option especially on later trucks and 250/350's.
If you do have one shoot me a PM or email at kellen302@gmail.com and we can talk money.
