Best F150 year/motor/tran/gears for MPG
You said highway so I would go 300 i6 5 speed 3.08. Some hypermilers claim to get 20+ with this setup, but 17-18 would be more realistic. A lot of people say the older carbed 300 with a 4 speed and 2.7? Gear get better than the efi. Idk, never had one. Terrain in your area will play a big role, if you live in the mountains like me, a 3.55 might be a better option. I get 16.5 driving nice with a 300 auto reg cab lwb 2wd 3.73. I travel mostly 55mph hwy. never had it on the interstate with this gear. Last tank was only 13 when I drove the truck back and forth to work with a bunch of red lights. In contrast, a 5.0 will make a much more enjoyable interstate ride, my father-n-law has a 90 302 4x4 swb 5 speed that gets about 12 around town. I don't know what his gearing is but its factory so 3.08 or 3.55.
I had a full-size Cherokee with the 258, carb, 3-speed manual, and something like 2.75 gears and it got ~ 20 mpg. Makes me think a F150 with a 300 and ~2.75 gears would be a good match.
I am a fan of in-line motors, but not a fan of internal slaves (which I think all the F150 5-speeds had).
I understand you can't have everything you want.
Roy
Roy
I have an 86 F150 4X4 reg cab SWB 5.0 EFI with SROD and 3.55 gears that will easily do mid 20's with 235/75/15 highway tires. I previously had a 92 Bronco with 4.9, E4OD and 3.55 gears that managed about 15 mpg. Truck had 30X9.50X15 Goodyear Wranglers. Not enough difference in displacement between the 5.0 and the 4.9 to make much of a difference in fuel consumption. Suspect the difference here is in curb weight, tires and transmission.
FWIW, I used to have a 73 Bronco with a carbed 302. It got around 20 mpg. When the 302 blew up, I built a mild 351W with a 4bbl. Hooked it to the same 3 spd manual and got about 1 mpg better. Was also able to light up all 4 tires, but that's another story.
A lot of the mileage results will also vary with pressure from the right foot.
Wow.
That SROD was a 3-speed-plus-OD manual, right? Aluminum housing? External slave?
Your 302 to 351 story is also interesting. OD, gearing, tires, the right foot...makes a lot of difference as opposed to CID.
Roy
My 95 150, 5.0 m5od 3.55s 4x4 with 31x10.5 tires will hit between 15-19 dependent on how I drive frustrated with traffic 15 most of the time its 16.5. When I got it with 155k on it after I tuned it up she would do 20 on long trips but at more than 240k she's getting tired and don't road trip her anymore.
5.8L/E4OD/3.55 with 235/75R15 tires will net decent, though not best, mileage. I frequently saw 17mpg highway at 65mph (empty). Add a headwind, excessive rest stops, more speed, etc. and that number goes down pretty fast. Had a few fluke tanks, both higher than I thought possible and lower than I thought possible: 20.5mpg (tailwind on glare ice for 300 miles, no stops, 45-50mph) down to 7mpg (towing at trucks rated limit). Realistic average highway was 15, that's what I used when figuring trip costs and it worked out well. Added tall tires, small lift, flatbed, and mileage peaks at about 15mpg now, with a realistic average closer to 12 or 13. In town, don't bother calculating it...
