2003 ford ranger 2wd HELPP!!!!
Old 11-09-2015, 08:22 PM
Fordgirl808's Avatar
Fordgirl808
Fordgirl808 is offline
Hello I have a 2003 ford ranger edge 2wd. When I start it it starts shaking bad then when I put it in reverse or drive and keep my foot on the break it rocks back and forth a good two inches. My check engine light is on it says that it was the mass air flow sensor I changed that and it's still doing it , it's driving very poor to and sounds like crud. Anyone can help?
Old 12-24-2015, 10:58 AM
78 PEB's Avatar
78 PEB
78 PEB is offline
Have you checked spark plugs and wires? Run a compression test? Need some more input to try and help out!
Old 02-27-2021, 09:04 PM
StepRanger's Avatar
StepRanger
StepRanger is offline
I've had two different cars do this due to bad motor mounts. One barely ran at all, the other lurched around pretty good and was down on power. Switched out the broken mounts and, voila, it was fixed.
sonicranger
1983 - 2012 Ranger & B-Series
09-17-2003 04:45 PM
20RangerEdge03
07-23-2003 08:28 PM
Quick Reply: 2003 ford ranger 2wd HELPP!!!!
