Will a 6637 filter get wet when raining?
I had the same concerns as you about that. After many years of using this filter setup exposed under the hood there has been no damage to the filer element. Actually, as you drive down the road the air builds positive pressure under the hood that enters through the radiator area and exits through the gaps between the hood and fenders. This airflow over the filter element prevents the rain from saturating the filter. Sounds abstract but that is the reason why it does not get wet.
You may want to check out a pre-filter too. They are made of water repellent material and are washable.
TEMP* | 20-2087 | 8775
Take a look at this link. Diesel Brads comment on post #16
https://www.ford-trucks.com/forums/1...or-an-obs.html
The donaldson BO85011 is supposed to be water resistant also.
The donaldson BO85046 is hydrophobic and spec'd for marine and high humidity. The above mentioned post stated the 85011 is hydrophobic also, but the 85046 is treated to resist mildew and such for repeated exposure to high moisture. The 85011 is what the Tymar kit uses from what I understand.
Received 3,090 Likes
on
Ford - 94-97 'OBS' 7.3L - Intakes, Intercoolers & CAC Boots - Intake Systems & Filters - 6637 Kit & Related - Riffraff Diesel Performance
#34.99
i prefer to use the riffraff pre filter cover. they are made by a FTE member for Riff too, so you are supporting a member, and a site supporting vendor too.
#34.99
#34.99
on
#34.99
#34.99
