Distributor wiring?
Distributor wiring?
Ok all, I was looking at my relays again todays and decided to pull the entire engine wiring Harness and go over it good and clean up connections. The first thing I noticed is that there is a black ground (to the fender) {87 F150 custom 2wd, w/AC, and 4.9L 300I6} hat had a bare (frayed wire) connected to it. Since bare wire is seldom good (this is the reason I pulled the harness) I started bck tracking to see where t came from and if there was any damage. Basically it just runs with three other wires to the distributor. It is not connected to anything, it is just wrapped (coiled) loosely around the three main distrbutor wires. Is this normal, or is this someones invention? It is connected to a ground, and I know that coiling around an electic current can cause a Magnetic field...But it is literally just a bare wire wrapped arounf the three distibutor wires, Yello Lt. Green, Drk Blue & I believe Blue Orange. I know the dark blue is the IGn Ground. My issue with the EEC elay was I had constant power on what I thought was supposed to be the Ground.... I am thinking this may be part of the problem. Any ideas?
Does it run if so leave it
I don't know if it's duraspark or fuel injected I recall the duraspark distributors were grounded and the black wire ran to the module to ground it being as it was already grounded on most(?) applications it was less than useful and I believe that's what you're talking about
nevets350
05-17-2014 05:47 PM
lakecityg
Electrical Systems/Wiring
06-27-2011 08:37 AM
superman64011
01-10-2005 11:39 AM
