No power, smooth idle
With winter approaching I decided to change out my glow plugs. 1 was bad for sure, so I put all new ones in along with a new valve cover gasket and wiring to the injectors/plugs. Shoved it all back together, everything worked as it should.
Drove to work for three days with no problems whatsoever (70 miles roundtrip) and on the way home the last day it wouldn't pull hills. No smoke, no rough idle, no check engine light. Got home and no codes, so I disconnected the batteries for awhile, drove it, and finally got a code for the MAP sensor (P1248) so I tested the electrical on both the MAP and EBP and got 5v input on both. Swapped them both out, cleaned out the line going to the EBP sensor, put a new signal hose to the MAP, and now I get white smoke on takeoff, no power, but it's still idling smooth as silk. No codes either.
What. The.....
What. The.....
Changed the fuel filter first thing and nothing looked out of the ordinary. I changed it with an O'Reilly brand (I know, I know) 2-3 months ago and thought maybe it was the problem. It wasn't.
So you had bad fuel that caused all of this? I figured it would run crappy with bad fuel. It didn't even start smoking until after I changed out the sensors and cleaned the lines.
I have a friend with a 6.4L. He got bad fuel (gas/diesel mixture) at a station. Cost $8500 to fix it. Fuel station had several claims against them that week, and could not deny it was them. They paid the $8500. Just to let you know you CAN get the station to pay. His insurance went after the station hard, and they paid up pretty quick.
New air and fuel filters put in as soon as I got home. I've double and triple checked the IC boots thinking that I might have forgot to tighten or seat them properly when I did the glow plugs. She's making 0 boost right now, like the wastegate is stuck open but it isn't. I'll check the ICP tomorrow. Would that not throw a code of some sort?
