Billet compressor wheel and quick spool on stock sticks
But I seriously think you need to look into why your boost is low. I think your losing some ponies somewhere (and potentially causing higher egts too).
I have been VERY proactively chasing why I have low boost and high egts for the past 8 months since Ive owned the truck. I cant figure it out. I dont have any boost leaks, and I just redid up pipes. I either have a fuel leak, a bad turbo, or a bad hpop. But nothings sending even soft CEL codes. Ill end up having to do a terminator, Efuel, and the turbo. But the turbo is cheapest so itll go first.
Ive had a few issues with the trucks fueling system. My fuel filters keep getting plugged off. I need to drain and clean the fuel tanks, but I was just waiting for efuel before I did that.
I went with the Pro-torque app and the Vgate but it doesnt show me Fuel pressure.
I have some shaft play, but its only to one direction. My turbo wheel also has been dusted. It has a sharp jagged edge on one of the wheels.
Right now my boost tops out at 17 psi @ about 2950rpms. Id like to get my psi past 20, and get it there before 2800 rpms. Ideal conditions would be the new billet wheel spools up quicker and to 20psi. Ill try it first, thanks for the advice Cowmilker. With the 1.0 will my egts rise by alot or are we talking 50degrees? Also have u tried the 1.0 with the 6.0 intercooler?
BTW, when I climb hills (8 to 10% grades on the east coast), I do so at 2800 to 3,000 RPM in 3rd gear for 5 to 10 minutes at a time. The red line is 3200 and the truck won't fuel much past that. The idea is to climb at peak HP anyway. Higher engine speed will keep your EGTs in check.
If you want maximum power hill climbing, you might want to look into water/meth injection. It's about the only way that I know of.
The elevation here is definitely a factor. I know all about the power loss from thee elevation. The mesa goes from 3700 or so ft to 12500 ft in just 10 miles. It's an MFer of a hill climb. It's a about 40 mins of constantly pulling at 2900 or higher rpms. I know at 12500 ft there's a 25% power lose then the turbo brings back about 7% of that, then I have another 25% lose of power from the auto tranny/tcase/drive shaft/axles/tires.
If I could get a about 20psi of boost at 2750-2800rpms while towing. I could get my egts manageable, not bog down, and keep my engine from being overworked. The issue I'm having now is I'm either going 10mph up the 45mph hill or I'm going 40mph up the hill at 2900-3100 rpms to keep enough boost to hold egts at bay. Anything in between is about 5psi of oost and 1400egts.
I've never run water injection on anything, other that some failed home made experiment on an old GMC truck years ago, but I second Nicks suggestion. Seems like it would be worth checking into.
I'm not sure about the 1.0 housing and upgraded wheel. Seems like it will spool up faster while accelerating but once you reach your steady climbing speed the EGT's will still be high or higher due to the increased backpressure. Since this is a dedicated towing truck the best long term solution for the EGT's may be a bigger turbo. But I don't do much heavy hauling and my turbo is stock so I can't provide any real experience.
I really don't think the 1.0 housing is going to help you with that much of an incline. I could be wrong though. If I were in your shoes I would start with just the wheel. It should help increase boost and by not changing out the housing your egts won't be any higher
#28
the first times the worst. If you decide fairly soon afterwords that the 1.0 is what you need it won't be to bad to pull. Just a pain in the ****. Superduties don't have 160cc injectors. Or they would have a serious egt problem. They also have a wastegate.
