97 7.3 motor build PICSS!!!
I have a 94 f350 7.3 turbo with a 97 motor and I need help with finding out where to hook up certain things, well heres some pics.
/Users/Talia/Desktop/IMG_3628.jpg
What's missing?
What connects here?
What is this hose?
What goes here? Degas bottle?
What was here?
Where can I find a window crank?
What are all these wires for? Truck is xl so maby for optional power windows, locks etc.?
Why is this bypassed?
What does this switch do? (driver side seat)
What do these connect to? (driver side where intake goes)
Sorry I know I have a lot of questions but I own a 6.0 and this is my first 7.3 so i'm learning.. Thanks in advance for any help
What's missing?
What connects here?
What is this hose?
What was here?
What's missing?
What connects here?
What is this hose?
Maybe the over flow for radiator. The early trucks had a different radiator setup with over flow where the late trucks had a degas tank.
Yes
What was here?
LMC truck may have the components you need. Or a junk yard or post in the parts wanted sticky. Some one here may have it.
To trick the ac system to stay running.
Lumbar air cushion.
The round one looks like the icp sensor maybe.
What's missing?
What connects here?
What is this hose?
Yes
What was here?
Lumbar air cushion.
Ahh, yea I bought her 3 months ago and she has a complete new ac system, compressor, accumulator, hoses etc. the only thing I saw not replaced was the sensor. And ok.. explains why it doesn't blow hard or cold...maby.. but the compressor does engage, also do you know anything about manual transfer cases?
The bad part is it had a bad connection and I did the zip tie mod and it worked. Then when i did all the work to it I decided to order a new pig tail. Put it on and it worked good for awhile but had to go back to the zip tie mod.
