5/16" - That's the number to remember.
So I did an oil bypass kit, along with a whole bunch of other stuff in preparation for a long haul soon. I skimmed over the instructions for the kit (translation - I looked at the pictures), because how hard could it be? I see the oil return plug and grab the 3/8" socket drive to fit in that square hole. Nope. OK... I thought it looked too big for the 1/4" drive, but I guess I have aquarium eyes or something. Grabbed the 1/4" drive and nope again - too big like I thought. This is a good time to look at those instructions in greater detail.
The paper says to use the 3/8" socket by 5/16" square drive. Uh.... They make those? Hitting the tool department at the Irish store, then Ace - I'm beginning to get the impression this is a specialty tool for auto mechanics. Well... not one to give up easily and I'm at Ace anyway, I shop the whole hardware section.
I found taps and extractors with 5/16" drives - I can always get on one of those with vise grips, but they are a lot of money for one use. I finally stumble onto a drawer near the screws/bolts that has key stock in it. There it is... 5/16" key stock for $1.10. I used that with a wrench to get the oil return plug out.
I won't drag you through the part where I removed the coolant drain with the 1/4" socket drive instead of the oil supply plug with a 1/4" wrench - I've dragged you enough already... for those still reading.
So... 9 1/2 hours under Stinky and I grab the gallon of JoJo soap, scrub brush, and Brillo pads to clean up - and that's when I realized my impending doom: My wife scoured the whole bathroom while I was under the truck.
on
When my Snap On square drive sockets were at work, I improvised by grinding down the end of a bolt into a 5/16" square and used a 6 point socket on the hex. I have fabricated many of my specialty tools, at home and work, out of necessity. That's what God made grinders and welders for.
I feel your pain, yesterday I did an oil and filter change on my truck, the wind was quite fierce & changed direction as I slipped back under the truck to replace the drain plug blowing the last drips in my face. After filling with oil I moved the truck, turned it around then reversed over the (full) oil drain pan!
Funny... Yesterday I had my Trans pan down to replace solenoid pack, messy job but I was able to keep it remarkably clean. Got it all back together and went ahead with a Trans flush. Got my hose hooked up to return line, had drain pan waiting under for drips. Well apparently I have a bad bypass valve because fluid came pumping out of the back of the Trans and all over the driveway. Huge mess!
I found my 5/16 square at tool King.
