Engine bay clean up and removal - Ford Truck Enthusiasts Forums
Old 11-07-2015, 01:06 PM
smilts smilts is offline
smilts is starting off with a positive reputation.
I just bought a 1981 F150 Custom with a 351m. I'm trying to clean up and organize a busy nasty engine bay. I have one pump I assume originally meant for Emissions. But it has no belt to it, and isn't being used. It seems to tie into a few different places and being unfamiliar with these engines I'm not sure what can be removed altogether, and what I need to reroute.
Old 11-07-2015, 07:34 PM
thedopefishlives thedopefishlives is offline
thedopefishlives is starting off with a positive reputation.
That pump, and its attendant piping, is the secondary air injection pump (or smog pump). I believe that it can be plugged, with some work; it's not a simple matter of removing the pump and fittings because it opens into the exhaust flow. It's vacuum-controlled, and the vacuum hoses can probably be disconnected and plugged at the source.
Old 11-07-2015, 08:29 PM
Thank you it appears to pipe into the intake. I figure plug there to block it off should suffice and just cap the vac lines as you suggested? Please correct me if I'm mistaken. I'll be tearing into it tomorrow as well as removing the carburetor for a rebuild in a couple of days.
Question's/Idea's on power washing engine bay timbersteel 1987 - 1996 F150 & Larger F-Series Trucks 6 03-18-2016 08:56 AM
91 f150 wiring diagram NotSoSporty98 1987 - 1996 F150 & Larger F-Series Trucks 2 02-08-2016 10:26 AM
Cleaning up engine bay FordYoungGun35 Appearance & Dress-Up 2 10-18-2013 12:45 PM
What cleaning solution should i use to clean my engine bay? tseng19 2004 - 2008 F150 8 03-27-2012 08:33 AM
Engine Bay pictures rmalottwtes30 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 16 08-28-2008 04:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
