Brake Dust on Front Wheels
Old 11-07-2015, 06:27 AM
Chilly-in-Vermont's Avatar
Chilly-in-Vermont
Chilly-in-Vermont is offline
I have a 2016 F350 4x4 that has brake dust on the front wheels after only 3000 miles. I have tried to find ceramic pads to replace the semi-metalic pads that are causing the issue. There is no listing for replacement pads that I can find. My question is will 2015 pads fit the 2016? Does anyone have the actual part numbers to see if they are the same. This is just one of the problems with having an early build vehicle. Thanks in advance for any help or advice.
Old 11-07-2015, 08:11 AM
Thenewboss's Avatar
Thenewboss
Thenewboss is offline
Unless you are hung up on aesthetics, this is not a problem, it's simply a by product of the brakes stopping the truck. I'm on my second Super Duty and both have made dust. There may be some aftermarket options available, but for the the money the motorcraft pads are best for me.
Old 11-07-2015, 09:04 AM
69cj's Avatar
69cj
69cj is offline
Auto Zone has ceramics for the 2015 for $103 per set lifetime warranty. Since there's a 2017 model change bet they'll fit the 2016. If not you can take them back. IIRC they are made by TRW.
Old 11-07-2015, 11:09 AM
17 Oaks's Avatar
17 Oaks
17 Oaks is offline
??? I ran outside to check mine, never noticed any dust and have no dust, never saw any on my '11 in almost 50k miles Wonder why?
Old 11-07-2015, 12:09 PM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
Sounds like someone is hard on the brakes.
Old 11-07-2015, 01:33 PM
69cj's Avatar
69cj
69cj is offline
Depends a lot on the wheels. My Platinum wheels with black insets show it quit well.
Old 11-07-2015, 01:37 PM
EO2SeaBee's Avatar
EO2SeaBee
EO2SeaBee is offline
As do mine.
Old 11-07-2015, 04:02 PM
Big-Foot's Avatar
Big-Foot
Big-Foot is offline
Ceramic pads will (many times) damage wheels that are plated or coated... They actually are harder than the iron in the rotors so the rotors shed material - sometimes RED HOT material... Ceramic pads ruined the front wheels on my wife's last car (chromed aluminum) and my last truck (coated aluminum)...
For what it's worth, I will happily wash away a little brake dust every now and again...
Old 11-07-2015, 06:03 PM
Lawrencew's Avatar
Lawrencew
Lawrencew is offline
Same
Originally Posted by EO2SeaBee
As do mine.
My Fuel wheels show it
Old 11-07-2015, 06:20 PM
69cj's Avatar
69cj
69cj is offline
I've installed ceramics on two late model vehicles and had zero problems.
Old 11-07-2015, 07:26 PM
22rimfire's Avatar
22rimfire
22rimfire is offline
Might I suggest using your exhaust brake more, even when not towing. It should help take some load off the brakes.
Old 11-07-2015, 07:36 PM
Ricohman's Avatar
Ricohman
Ricohman is offline
Mine show that dust in as little as a tank of fuel and I'm easy on the brakes.
Just wash it off.
Old 11-07-2015, 07:40 PM
Chilly-in-Vermont
For what its worth... this is my second 6.7 with the first being a 2011 that had 94K miles when traded. I had ceramic pads on that truck and had no problems what so ever. I need to find out from somebody if the part numbers for 2015 and 2016 are the same as there is no aftermarket listing for the 2016 as of yet
Old 11-08-2015, 08:27 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Wax your wheels and the brake dust won't stick as badly and it will come off easily.
Old 11-08-2015, 09:01 PM
bigredtruckmi's Avatar
bigredtruckmi
bigredtruckmi is offline
I have brake dust on ours. Took in to dealership. Said it was normal. Just wash front wheels more often with lots of soap. Works good.
Quick Reply: Brake Dust on Front Wheels
