Rear brakes sqeaking as im cruisin'
Not sure if they're crappy pads, rattling around, or brakes braking on in the rear. after about 3 minutes of driving, they start squeaking really bad. How can i tell if the master cylinder rod is adjusted correctly? what else could it be?
Wilwood master cylinder, tuff stuff booster, wilwood adjustable proportioning valve, front and rear calipers are the same, new gm metric mid 90's calipers from speedway
Was it fine to start with and just started or did you just install the system?
Open a bleeder on the ones making noise and see if they release.
Do you have a disc/disc master cyl? If it is meant for rear drums it will have a residual valve with a higher pressure than for a disc setup causing drag.
Need more info.
Need more info.
Could be a few different things. If the pedal adjustment is NG and the booster shaft is still pushing on the master when the pedal is up, or the pedal is not retracting all the way back. Pushrod on the booster matched to the master cylinder? If it is too long it could be pushing on the master with the pedal retracted. Can also try a return spring on the brake pedal if the pedal isnt coming back far enough.
And the residual valve you have is correct for the style brakes you have? Verify that if you haven't already.
I have 2 return springs on the brake pedal, I'll have to go look At the residual valve when the kids go down for naps. I'll check the booster rod also
Here is my master cylinder.
Wilwood Aluminum Tandem Master Cylinders 260-8555 - Free Shipping on Orders Over $99 at Summit Racing
