I got a Stiffy!!!
I got a Stiffy!!!
Okay guys, been a while since I posted, but I finally decided to post a question:
Why is my truck SOOO stiff?!
I mean it is ridiculous how stiff it is, I have owned a F-350 and a previous F-250 and it wasnt ever as stiff as this truck.
If I hit multiple bumps around a corner in the road, my truck will begin to shimmy out of the corner sometimes cause it is so stiff on the suspension, what gives?
Any ideas or suggestions?
Or any questions that you all have that I need to answer to get a better understanding of why?.
Thanks - P
Thanks - P
2. I am running 57psi in my tires
3. running 20 psi in my bags at all times
4. I have front coils springs
In regards to the cups I decided to take a couple pictures of the front suspension. Tell me what you think .
The top on the coil spring where it meets what looks like a "cup" is stock though, not aftermarket. And honestly, after looking at the types of leveling kits out there I cant see where one was installed, unless a taller coil spring was installed on my truck.
My truck did that so I replaced the shocks, the next time I went over the bumps that caused the shimmy it didn't do it. Are those the original shocks on your truck? I am on my second set of Monroe Reflex shocks and I really like how they ride however I don't go off road very often, maybe a dirt road here and there and they seem just fine.
I was told the min for mine is 4psi and max of 65 (I think). I usually keep them around 6 -8 unless I'm towing my toy hauler. Then I'll put somewhere around 50 in it. If i were to ride with anything more than 25 without hauling something, it'll shake the fillings out of my teeth. Its a little rough with anything more than around 8 though.
I don't understand how my rear bags are affecting my front suspension. Especially when I have had this problem since I owned the truck when purchased in April of 2015 and I have only just recently been keeping the bags at 20 psi. So whether or not the bags are inflated it still does it. Also, when shocks are worn or getting worn I was under the impression that they compress more, hence riding like a caddy. Not get stiffer. I am at a loss. I am not dismissing what you guys are suggesting. Just doesn't seem to make since. I don't know how.old those.shpcks are since I have only had this truck since April.
