Electrical Issues / 1957 f100
I have a mess of a wiring issues and I will soon replace it all with a new harness. In the mean time I have been just replacing the obvious damaged wires one by one. I was making progress and got the back lights working again... Until I tried to replace the fuses because they were pretty rusted and now both the front and rear running lights will not turn on. I assumed that the fuses I put in were not the correct size so I tried placing the old ones back in. Problem is not sure which one came from which slot. Also the metal on the end of the fuses was flaking off. I tried several times moving them around with no luck. So the question is does anyone know the correct fuses for the correct slots? There is 4 slots but only the right 3 being used. Thanks for any help!
'57 and early '58s had the light switch with one fuse. When PO added that fuse block, he may not have bypassed the fuse on the switch (making some circuit(s) double fused). When changing wires, you may have blown the fuse on the back of the switch. Check that one. As for which fuse goes where, that's anyone's guess on added circuits.
Yes,
that wiring looks to be in quite a state. Better to get the whole thing changed out sooner than later. I always use & recommend the "Centech" brand universal wiring harness system I have done quite a few jobs on clients vehicles with this system and have always had good luck with no problems. Also has a good price point for what you get and is well labeled and instructions are very clear.
Canadian production 57-59's had a bimetal circuit breaker mounted up around the same area as your pic as protection for the headlight circuit. dunno if the U.S. production units did.
When rewiring anything I always make sure to solder all joints, as well as a spot of solder on all crimp connectors. and always use shrink tube not electrical tape. Also use a spot of dielectric grease on connections and in sockets. This may sound like overkill but will ensure reliable function for years to come. Oh ya... and make sure and loom all wires for added protection from chafing.
Mikie
near Ottawa Canada
58 M-100 panel & 64 econoline p/u
Mikie
near Ottawa Canada
Thank you everyone. Think I need to take economan, actually it sounds like i need to just have him do it!
Ok, so got the fuses back in place and replaced the line between the stop switch and the light switch (for brake lights) that was totally fried. All seemed to be good until I tried the brakes and that same wire totally burnt from one end to another. So it is beyond me, either there is a short or overloaded circuit or who knows.
yep!
sounds like a dead short to ground, and it also sounds like someone has bypassed a fuse for the wire to have burned up like that.
Iffin' you are really stuck I have some Ford wiring diagrams here out of an old Glenn's repair manual. I have never had any luck scanning them on my machine here, but I can always drop one in the post to ya if you need and are not in too much of a hurry just lemmee know your mailing address. either on here or email me private:
economan(at)Hotmail.com
Mikie
near Ottawa Canada
1958 M-100 panel & 64 econoline p/u
Mikie
near Ottawa Canada
sere0501
48
01-04-2015 12:39 PM
90pioneer
04-25-2013 05:54 AM
