EGR leak...fix or delete?
Going in the shop next week for a leak on the lower cooler. I understand this may require a cab-off repair. with 175k miles and the desire to drive this truck another 5+ years, is it smart to fix the issue or delete the system? Thanks.
If you can delete and tune with out worries to your local laws then do it, you will have a much happier truck.
There is a great video series on YouTube of a Ford Master Tech doing an EGR Cooler replacement. It's a lengthy process. Degas bottle, battery and dip stick tube all come off as well as disconnecting part of the steering. It was about 4 hours for me my first time. I could probably do it in under three now that I've done it.
Finally got around to having a local diesel shop delete the EGR Coolers after they diagnosing my coolant leak. Imagine my shock when I get a call saying "sorry, coolers are fine, it must be a head gasket...do you still want the delete? because the labor cost is the same either way at around $1200."
Midwest Dually
6.4L Power Stroke Diesel
15
06-28-2011 11:42 PM
