Positive Ground questions
A 1955 F350 239 Y block is positive ground correct? So.....I'm working on my truck, trying to get it started, and while doing some research I found this out. Will this "fry" any of my electrical components? Could this be the reason I can not get the truck started? I know I'm an idiot for putting it in backwards but it had not been run in over 20 years and the cables appeared to be set up for that configuration. The truck has been turning over and I have spark in all but cylinder #8. Any words of advise would be greatly appreciated. Thanks in advance.
@Joe The cable ends were set up up for negative ground. (6 volt) The thing is my dad put new cable in way back when and I am not sure they are right. I think I might be best to go get new cables that will put it back to positive ground. I just didn't know if hooking it up in reverse would affect the ability for the engine to start.
What have you done to troubleshoot the firing problem? If only #8 has no spark, it could be the rotor cap or plug wire.
pilgrimbizket
07-08-2019 02:32 PM
hhight
08-07-2014 09:23 PM
Jaymz94
07-13-2013 07:24 PM
Pursual
24
04-26-2010 06:11 PM
