My truck is a 97 Ford Ranger 2.3 liter 2 wheel drive everything is stock. the rear driveline area coming from under the bed is making a loud metal scraping sound as I'm driving, whining from high pitched to low pitch squealing sort of noise check the rear diff has fluid check the brakes brakes are dirty but that wasn't the problem I don't know what else could be making the noise after I come to a complete stop or anything below 20 miles an hour it completely stops and then continuously does it on and off throughout all the gears. Also does it with truck in neutral while driving. Drive line looked ok as well
Reason: Not super duty. Small class truck
Have you actually looked behind the brake shields to see if there is a stone or something wedged in there. Take a long screw driver and gently lift the shield up and see if anything drops out.
I looked at the front as well. Seams like all 4 breaks are ok no rocks. I feel it's either my rear diff or driveline. Idk. I'm going to t take it to a mechanic soon. Truck has defeated me
If it's a u-joint in the driveline, it will be very obvious if you jack the rear end up to take the slack out of the shaft. A bad u-joint will be very loose.
