5.8 EGR
5.8 EGR
Did a code check and got the 33 for EGR. Depending on which book you look at it could be not opening or not closing. Anyway I replaced it which was a pain because the tube broke too but got it done with a new sensor and still get the 33 code. New valve so it should be closing properly. No vacuum ever to the EGR as far as I can tell. When I rev it up it should get vacuum right? Vacuum solenoid? Or computer not sending the right signal? How do I know which? No vacuum leaks and vacuum gets to the solenoid but never past it.
JRS2
09-28-2011 08:19 PM
paradiddle
02-06-2004 12:13 PM
