C6, goes strong, than slips, than nothing. N back again
I put a trans in my Mercury, it came out of a old Van I had, drove good 5 yrs ago or so... Anyways. Trans in the car slipped in all forward gears... But reverse went strong, leaked out of the front between the case and the pump. So figured I'd swap in the trans that was good. But used the converter, and the valvebody out of the trans that was in the car.
Anyways, took it for a drive. All was good. Spins the tires no slipping shifts awesome n all that. Than, it makes a funny noise, and nothing. No gears any direction. Shut it off, let it sit about 5 min.. And bam, it drives good again. Than it slips a bit in 2/3 and than nothing. Not forward or reverse gears... Let it sit. Start it back up n same thing. Goes like a raped ape, than slips a bit and nothing.
It has all new oil, I had drained the convertor too, adjusted the band, the modulator, the shift linkage, and new front seal. I'm at loss here.
Received 3,102 Likes
on
on
Well, I think I've got it... Turns out the insides of that trans must have had a lot of crap in it... I pulled the pan and valvebody today, the filter was half plugged, and the pan had a lot of crap in the bottom. Cleaned it all up, put new filter in, and put 10-15 miles on it and all seemed good. So I think it's good to go now.
truckboss
10-18-2014 10:22 PM
laneyboy6933
02-24-2008 10:46 PM
4fords
01-12-2007 02:27 AM
