Not enough fuel flow
ok, so I have a 1961 F-100 with an original 292. Yesterday, all of a sudden, it bogs under load. As soon as I hit the gas, it bogs and is almost impossible to keep moving. It had an aftermarket, clear fuel filter that was a little dirty, but also looked mostly empty. The truck would idle like a champ and I could see a little flow in the filter, but not what I would expect to see. When I disconnected the fuel line not a drop of fuel came out. I replaced the line all the way back to about six inches from the fitting on the bottom of the tank. Again, when cut the line didn't have a drop. Once all connected with a new filter it started right up and idled fine. Fuel started flowing (slowly). Again, it would not run under load. The fuel flow was minimal at best.
2 questions
Does the tank have a vacuum activated valve in it and do you think it may just be the fuel pump is ready to completely die?
Thanks in advance for any insight.
2 questions
No valve, but the tank might have some crud in it. Rust, scale, etc.
Every time I disconnect the fuel line anywhere between the tank and pump I've got gas all over the place, which makes me think your tank line is plugged possibly.
Sometimes you can at least temporarily get a flow going by blowing compressed air back into the tank through the fuel line. Make sure you remove the gas cap first. This blows any possible crud back out of the lines and into the tank where it came from.
Also, make sure your gas cap is vented properly.
Some of the fuel pumps have a filter built in inside of a canister, either metal or glass typically. People often forget there is one and it can get plugged up with crud and slow the flow to a trickle, too. But to me, that would be secondary to getting a good syphon flow out of the tank first.
I will try to get it to at least gravity flow before replacing any more parts.
I can shine a light into the filler tube and see that the tank is pristine. Not sure what kind of junk could be in there.
One79one71
18
02-18-2017 04:10 AM
EightGodzillas
13
06-30-2015 07:54 PM
Ford 67 Ford
06-05-2013 06:22 PM
55Bubba
08-16-2004 01:47 PM
