86’ F250 Wheel/Tire Setup Recommendations
Have an 86’ F250 4X4 that I’m starting to recondition/restore, and have some questions regarding wheel and tire sizes.
Mainly, are there any recommendations for wheel and tire setup?
I’ve been tossing around the idea of getting 16 or 17” steelwheels that are about 8-9” wide. Probably won’t put any massive rubber on themsince cost will be a factor, but would like 31-33” tires.
This will be primarily a camping/hunting truck, so will beoff road a lot, with some highway driving. Really just want a capablewheel/tire combo, with limited to no modification to the truck. Obviously I’dlike it to look nice, with a little wider stance than the stock wheels give itnow.
So I think I've decided to go with LT265/70R17 BFG AT T/A KO2 mounted on steel 17X8 wheels w/ a 3.5" backspacing. It looks and sounds, from what I've read, will help clear steering knuckle as well as fill out the wheel wells and give me a slightly wider stance than stock.
Anyone see any problems or have a similar setup?
Thanks again for everyone's support.
Found some steel wheels on the typical sites (summit, 4wheelparts, etc) while I've been trying to figure this all out, but will probably search on eBay, Craig's list & a couple other local online classifieds though I've always been weiry of buying autoparts that way.
Really like the procomp wheels though!
on
Why go to a 17? 16's are cheaper unless you are looking at using takeoffs, but most OE equipped tires have no place on a 4x4 that leaves pavement. Clearing the knuckle or brakes are not a worry, 16" is the stock size on these trucks. I would look at a 16x8 with a 285/75R16(33x11 or so) or the aforementioned 265's.
I have gone as big as 315's on a stock F250, and it is tight, but, 315's are never cheap to buy.
Like the idea of 16X8 with 285/75R16. Will do some price comparing tonight but know if I can stay with a 16" wheel, I'll save a little in the long run, so as long as I won't have issues with clearance, that's most likely what I'll do.
I was afraid you were going to get 17 inch rims off a later truck. I think most of those have the metric pattern and won't fit.
Make sure also you always at least get the LT's. They make a lot of 16 and 17 inch rims for regular light duty SUV's and their load ratinng would not be high enough for your f250. I think they have a letter rating for the load range of the tire if you want to do some research on it.
But really, I've got a good friend who will be ordering direct for me. He hasn't worked on many older Fords so he recommended doing some research into what sizes others have had success with. Once I give him the sizes, he'll make the order using the F250's info. I'll be sure to double check about load ratings before we purchase. Thanks.
