1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Wiring under cab, 2015 f350
Old 11-03-2015, 05:42 AM
Ridge's Avatar
Ridge
Ridge is offline
I just bought a used 2015 F350 crewcab XLT, I as under it looking to see where running boards would attach and seen it looks like a 2 wire pigtail with a female connector close to that area where mounts would be, it is on both sides in same place, is that for lighted running boards or power running boards?
Old 11-03-2015, 06:07 AM
Duwop's Avatar
Duwop
Duwop is offline
Auto retractable boards
Old 11-03-2015, 06:10 AM
RightWingNutJob's Avatar
RightWingNutJob
RightWingNutJob is offline
Your description sounds correct. Connectors are on the outsides of the frame rails. towards the rear of the cab, about 6 inches forward of the rear cab mounts. There are small waterproof plugs in the ends.
Mine were live, so I wired them up to LED running board lights. They are on the same circuit with the cab lights. They power up whenever the door is opened, or unlocked with the key fob. They dim to off when the cabin lights time out as well.
These connectors are part of a lighting circuit. I don't believe they'd provide enough power for running board motors. You could use them to trigger a relay to run retractable running boards; to open or close them, but you wouldn't be able to directly power the running board motors off of them - the lamp dimming function would mess up the operation of the motors
Old 11-03-2015, 07:59 AM
Ridge's Avatar
Ridge
Ridge is offline
That's good, I am glad they power up when opening the door, now I have a reason to add lighted boards or just lights under cab
Old 11-03-2015, 10:15 AM
Lonewolftx's Avatar
Lonewolftx
Lonewolftx is offline
But the LED running board add on lights stay on when the headlights come on at dark, correct?
Old 11-03-2015, 10:46 AM
RightWingNutJob
No they don't operate with the headlights. If they're wired into the pre-existing connectors under the cab - they go on & off with the dome lights.
To have side running lights that operate with the headlights, you'd have to splice into a wire for one of the parking lights, or tap into the trailer lights circuit on the towing wiring harness
Old 11-03-2015, 10:54 AM
auburngrad's Avatar
auburngrad
auburngrad is offline
Does anyone know what to call the connection or where to buy a plug to connect to those wires. Looking at adding lights that are not from ford down there and would like to set up as plug and play.
Old 11-03-2015, 11:08 AM
RightWingNutJob
Amazon sells a Ford compatible speaker connector that fits:
Amazon.com: Metra 72-5600 Speaker Adapter for Select Ford Vehicles: Car Electronics Amazon.com: Metra 72-5600 Speaker Adapter for Select Ford Vehicles: Car Electronics
I cut off the other ends and soldered the wires into my new harness. I shrink-tubed it all, and added lots of Di-electric grease inside the connector. So far no issues with corrosion.
Finally got it to let me add pictures. (Cell phones are not good for low-light shots.)
Old 11-03-2015, 11:11 AM
Lonewolftx's Avatar
Lonewolftx
Another question then. What color was the wire as I am adding inside foot well lights on D & P side and want them to work with the dome lights like your setup. Looking for the wiring inside the cab if possible. Thanks.
Old 11-03-2015, 11:25 AM
RightWingNutJob
I don't have a wiring diagram for the cab. ("Juststrokin" may be able to look it up?) You could hook up your foot well lights to the same line as the running board lights - you'd just have to feed it back into the cab.
Using those same connectors, I also have it wired up for my Bed Lights. I can click my key fob, and light up my bed for 30 seconds, or it stays on as long as the door is open. It's also tied into an upfitter switch (with some blocking diodes), so I can turn on the bed lights separately from cab lights - unfortunately, I need to keep the key in the ignition to provide power to the upfitters.
Old 11-03-2015, 11:46 AM
Lonewolftx's Avatar
Lonewolftx
No Running Board Lightd
Unfortunately the 2016 LKR's don't come with the running board lights, like my '06 did. Hence the need for wire color.
1965F100(3onthetree)
06-20-2018 06:20 PM
Red97
35
02-08-2013 08:35 PM
jazz77
07-27-2011 05:58 PM
bigsteve1969
Ford Truck Parts for Sale
12-29-2009 04:26 PM
Quick Reply: Wiring under cab, 2015 f350
