Dirt, Gravel, or Slag Floor?
I store my truck under a "lean to" that is attached to the side of my workshop in my back yard. It currently has two open ends (to drive straight through), two walls, a roof, and a dirt floor. I would like to do something with the floor.
I am trying to decide between keeping a dirt floor, a gravel floor, or a slag floor. Which do you think is best for vehicle storage and why?
...If it is high in clay, i would suggest tilling about 1/2" directly under you truck with either gypsum or sand to create a more permeable layer with a clay catchment underneath. You can tamp that down to give you a firm surface, then top off the whole thing with a good layer of gravel.
This will prevent any drips from migrating to other areas of your property and aide in keeping water out with a slightly higher than grade build up.
Also, not sure what building code looks like near you, but if the material is permeable, such as gravel vs. concrete, there is typically no issue with impervious cover rules.
If you are referring to slag bi-product, I would stay away from that stuff. It is typically full of whatever media it was used for and the finer material will not provide better draining than a larger sized gravel.
My first question is. where do you live? (Why haven't you filled out that portion of your profile yet? It's something like Location in the third pane of some settings page in your User CP).
Back to your weather... does it snow and freeze? Rain a lot and make mud? That kind of stuff I would think would dictate what you'd want to go with...
Originally Posted by Diesel_Brad
Concrete or asphalt. Both will stop the ground moisture from coming up
Noe of your other options will stop the moisture
Am I wrong?
The biggest problem that will ruin a any vehicle sitting around is mice. Make sure you put some poison out or some other method.
Dryer sheets in the cab and under hood work Very well(then they dont store the poison in your hearer box)
I dont know what you are calling slag. However, when talking about gravel you have class A (which is washed rock or marbles like Jim said) and you have crusher run (which is marbles with soot, fly ash and smaller aggregate mixed in). Crusher run packs really well. Class A just rolls around and wont stay put. They can be purchased in sizes anywhere from 3/4"-3".Then you have screenings. Screenings are 3/8 or smaller chips with fly ash and soot. It will pack like concrete over the years if it is driven on and wet down frequently. The products with the fly ash will get crap in your truck every time you walk on it and get in though.
I guess item #4 is a local term stemming from a NY State DOT spec "Item 304 .12" for road base.
Around here we use the 3/4 and under bluestone for driveways and parking areas.
The sharper angles of bluestone seem to 'lock' and stay put better.
If you use a plate compactor in no more than 6" lifts it gets very stable.
Build it up a bit above grade if your soil is slick so it doesn't silt in.
http://www.redwingsandandgravel.com/runofbank.html
