4.9 vs 5.0
Graph showing HP/TQ. This difference pretty much holds for all years, although the actual numbers are lower in the '70s 'til the early '90s.
The 300 six makes it's power at lower revs:
http://jastrauss.fastmail.fm/1990_p16.jpg
Fuel economy will depend more on how it's driven and where. Both engines can be OK on gas in a pickup, and both can be total gas hogs if not running right or run hard.
Total overall condition and equipment would be the guide. Better to have a creampuff six vs. a thrashed V8 and vice versa.
are looking to buy a truck and trying to decide on an engine ?
i have never owned a 5.0 but i suspect the difference between the 2 in terms of mpg is not even worth considering. more important will be : transmission, rear end, and weight (1/2 or 3/4t, swb or lwb, 2wd or 4wd).
That combo will be ok with the stock smallish tires. Add 31s or more and it's going to hunt between 3rd and 4th on level ground.
The AOD by '88 had most of the problems ironed out of it by Ford, so if it works and shifts ok with clean fluid it's probably as "safe" as any old used auto trans.
on
300 is a truck engine, 302 really isn't. I've driven both and the 300 is no hot rod, but neither is the 302. 300 will be torquey and fun usable power, 302 has to rev to be fun. 300 will get better mileage, its only fault is that it will never have a v8 roar. Turbo mufflers make then sound decent though.
on
I have both a 92 f150 2wd SCSB 300 I6 with the M5OD running 3.08 open and 235 75 15 tires and a 88 F150 4x4 RCLB 302 with C6 3.55 (or 4.10 haven't verified yet) with 31 10.5 15 tires.
The 92 gets 2-4 mpg better then the 88 but the 92 also has 80K miles on the rebuilt engine where as the 88 has 800 miles on it.
The 92 has more torque but the 88 has more overall power granted I am turning 2500 rpm going 50mph (some slight performance parts in the 88).
The 92 does have overdrive but I have yet to need it as I would have to downshift again on the hills around my part.
Truthfully to me for the little gain in MPG I would rather drive my 88 however I hope to drive my 92 more since the 300 inline is known to last a very long time (not that I don't think my 302 won't last as long) plus the 92 doesn't have a bad transmission right now.
Trav
Trav
I had a 4.9 the motor was excellent I literally tried to kill it on a few occasions and never succeeded. It had 280k on it when I had it in high school and it's still being driven by the guy I sold it to and he commutes 30 min to work daily. If you do the math that's more than most 302 motors can dream of haha
