New 6.2, oil consumption?
I have a 2015 F250 with the 6.2. Truck is basically a daily driver, no heavy towing so far. It has about 3,600 miles on it and it appears to have "eaten" about a quart and a half of oil. No sign of oil in the coolant reservoir, no milky residue on oil cap, no sign of smoke on start-up or any other time.
Any thoughts? Is this normal for a new engine while it breaks in or a sign of trouble? Thanks in advance.
AVOID!!!! just my experience. Had to buy some one time due to an emergency, and of the 3 quarts of same viscosity, one was noticeably thinner than the others. I literally had to stare at the label to make sure I was not going crazy.....
on
On the Pennzoil.. found this interesting :
About Shell Lubricants
The term ‘Shell Lubricants’ collectively refers to the companies of Royal Dutch Shell plc that are engaged in the lubricants business. Shell Lubricants companies lead the lubricants industry, supplying more than 12% of global lubricants volume. a The companies manufacture and blend products for use in consumer, heavy industrial and commercial transport applications. The Shell Lubricants portfolio of top-quality brands includes Pennzoil®, Quaker State®, FormulaShell®, Shell TELLUS®, Shell RIMULA®, Shell ROTELLA® T, Shell SPIRAX® and Jiffy Lube®.
I have a 2014 F350 with the 4:30 rear. Have towed my fifth wheel 2500 miles from Florida to Delaware and back plus an additional 5000 miles and never had to add any oil to the truck, before the oil change. Now with 15,000 on it and doing mostly local driving it still does not use any oil between oil changes. So, get out there and put some miles on it and hope everything settles in as it should. Good luck!
I have been told by a friend that dealers have a hard time reading a oil dip stick
Now it sounds like in this case at 3600 you didn’t have an oil change yet so not sure
But I would read the dip stick after an oil change at the dealer
Think about it if they short you one quart for every oil change they do it adds up
And one quart low won’t make most people take notice….
Sorry to be negative but I have heard this story
And for me in a personal way i know the dealer I deal with doesn’t chaco the oil level after an oil change
shad9876
39
03-24-2011 04:55 PM
