Test drove a 6.0 today
Test drove a 05 6speed 6.0 today. It only had 99,000 miles. The truck had some good acceleration and everything looked good. I really liked it but it seemed to loose power between 3 and 4th. As the engine was revving up it almost seemed to loose all power . I was stepping on it kinda hard. Just wondering if this is a comimon problem? How expensive is a new clutch? Any info would be appreciated.
Thanks
Gilbert
Thanks
Gilbert
Well, if everything checks out, and you need a s sounds like a pretty rare opportunity. Shifting manual transmission, would be hard not to loose boost, between shifts so I think it really depends on what is happening with boost. With those low Miles, no doubt it needs a turbo unison ring clean and lube, I would also count on some other maintenance, fuel and oil filters, blue spring upgrade, check batteries, alternator ect ect.
PDX_Doug
04-03-2008 02:50 PM
