Alignment issues
Alignment issues
I just installed a 2" auto springs leveling kit on my 15 FX4 with no problems. I took it to firestone for their lifetime alignment and they said it was good. On the way home I noticed it pulled hard to the right. I rescheduled for later in the week and took it back in. They are now telling me they can not get it aligned because of the leveling kit. The caster and camber are slightly off on the drivers side. Caster 4.2 and camber -.8, both in the yellow. Everything else is in the green. Toe is .10 on both sides. They are telling me I need to take it to ford to have it done right. Mentioned something about shims maybe. All I know about is a camber kit for some trucks. All my research seems to read that most do not need camber/caster adjusted after the 2" kit only toe. What do you guys think? Could the caster/camber being slightly off on the drivers side cause it to pull hard right still? I've had it to firestone twice now and I just get the feeling they don't know what they are talking about, but I could be wrong.
This isn't an apples to apples comparison, but after I lifted my F250, I had all kinds of fun getting the alignment dialed in, eventually had a custom shop that installs lifts get it corrected. Took a couple of days, mostly waiting on parts, but they ended up using adjustable caster bushings.
As far as I know the camber is set by the lower control arm bolts/slots. If you didn't loosen the control arm bolts when installing the lift install there shouldn't be any adjustment required for the camber. Only toe should need adjustment. Well, that's the way mine was but I only installed a 1.5" lift in the front.
zach_barrow
11-23-2004 11:25 AM
